580 Case backhoe. Missing... trouble found.
Ranchingelect
05-14-2007 18:19:05
I borrowed a backhoe the other day to dig in sewer to my house. It didn't event have enough power to pull itself in 4th gear. I found out it was only runing on the front and back pistons. A compression test revieled that there was no compression on the center two cylinders. Hmmm. So I pulled of the head and found the head gasket blown out between the two cylinders. Has anyone else had this happen to them. Why would a headgasket blow like that?
leon phelps
05-14-2007 19:52:44
 Re: 580 Case backhoe. Missing... trouble found. in reply to Ranchingelect, 05-14-2007 18:19:05
Could be age of head gasket, could have overheated....only two of many possibilities.
Be sure to look over the cylinders before putting it back together. Also check that block and head are perfectly flat.
Good luck.
