Case 430 problems
Don Rudolph
05-13-2007 17:11:12
Our new 430 has a few glitches, any advice? The PTO continually turns and the hydraulic system will not lift the corn planter. Thanks for your help! Don
Wisconsin Bill
05-14-2007 21:54:49
 Re: Case 430 problems in reply to Don Rudolph, 05-13-2007 17:11:12
I have a 530CK with backhoe and no PTO. For the hyd lift, is there water in oil? MIne did not work with creamy oil-had a water leak. Is the hyd filter plugged? Mine has a gauge of green or not signifying not enough pressure. Is oil level low? My reserve tank is the loader frame-it needs to be full to mark. If not enough pressure from pump, those clutch packs may heat up and warp from the heat to possibly cause it to always turn-even with a slight load which normally would stop it. I ended up replacing the pump-very expensive, but it now works fine and was way cheaper than buying a new unit or someones other problems on another used unit. While apart, I repainted it and it now "looks' new again.
Wisconsin Bill
05-14-2007 21:52:28
I have a 530CK with backhoe and no PTO. For the hyd lift, is there water in oil? MIne did not work with creamy oil-had a water leak. Is the hyd filter plugged? Mine has a gauge of green or not signifying not enough pressure. Is oil level low? My res tank is the loader frame-it needs to be full to mark. If not enough pressure from pump, those clutch packs may heat up and warp from the heat to possibly cause it to always turn-even with a slight load which normally would stop it. I ended up replacing the pump-very expensive, but it now works fine and was way cheaper than buying a new unit or someones other problems on another used unit. While apart, I repainted it and it now "looks' new again.
D13
05-14-2007 08:41:13
Independent or live PTO? If live but not independent, should stop with the foot clutch in.
jr @beaver machine
05-14-2007 06:05:15
Don, do tell me where you found a "new" 430 CASE tractor! If it is the true independent PTO, there is a brake on it. More than likely the plates are buckled from slipping. Try to adjust it according to the book. If no book, call and ask for JR or Dick. (920) 897-4035
Don Rudolph
05-14-2007 18:17:25
 Re: Case 430 problems in reply to jr @beaver machine, 05-14-2007 06:05:15
JR,
Thanks for the info! Its "new to me" is what I meant. It is a 1969 model and I really like it-just some minor problems to work out. If I can't figure it out I will definitely call you. Don
Tom (Ks)
05-13-2007 19:45:21
Don, the pump puts out 10 GPM at a pressure of 1450 to 1550 PSI.
dctom
05-13-2007 17:40:43
DON, PTO HAS NO BREAK WILL TURN WHEN NOT LOADED WILL STOP WITH SLIGHT LOAD, LOTS COULD BE WRONG WITH HYD DONT KNOW WHAT TOM
Glen Wright
05-15-2007 14:04:34
 Re: Case 430 problems in reply to dctom, 05-13-2007 17:40:43
dctom The 430 does have a break on the independant PTO. When the clutch lever is all the way forward the clutch rest's against the break. Glen
