Phil (NJ,AZ,Sask)
steve n carol
05-12-2007 15:13:38
Phil, I just read a post by you (from the past). You mentioned that you 'use the backhoe as your workbench", WHAT A GREAT IDEA!!! thank you for sharing your experience. This will save me lots and lots of time and effort when I change the seals on my boom cyl!!!!
sl
PS. could I remove the ram by power instead of a come-along?
Phil (NJ,AZ,Sask)
05-12-2007 15:35:58
 Re: Phil (NJ,AZ,Sask) in reply to steve n carol, 05-12-2007 15:13:38
[quote]could I remove the ram by power instead of a come-along? [/quote]
At that point the piston & ram are loose, the large Cylinder Nut is off. You will lose some fluid when it comes out, but under hydraulic power you would dump >5 gal.
I use a come-a-long because I am working alone
and need to control/hold the RAM from damage when it comes out of the Cylinder.
Hope this Helps,
steve n carol
05-13-2007 09:19:41
 Re: Phil (NJ,AZ,Sask) in reply to Phil (NJ,AZ,Sask), 05-12-2007 15:35:58
yes, that does help. thank you!
