rockshaft seal
robgest
05-11-2007 13:52:12
I am having a bear of a time getting the new seal over the piston( any ideas)? Also in what direction should the seal face?
Case 530 CK
Roger (Mi)
05-13-2007 05:38:34
 Use an old and very dull screw driver in reply to robgest, 05-11-2007 13:52:12
I use a very dull screw driver. Grind off any sharp edges then use an electric wire buffer wheel to make sure it's dull. Use that tool only for installing hydraulic piston seals. The lip of the seal ALWAYS faces the hydraulic oil source.
rob gest
05-13-2007 06:02:42
 Re: Use an old and very dull screw driver in reply to Roger (Mi), 05-13-2007 05:38:34
Thank you for the help. I have seen that you are a great help to many people on this site. Keep it up, we all thank you.
