As installed on the tractor, the release valve is aft and the control valve is forward. The release valve is the one you can see the seal on the plunger w/o taking the block apart. The parts manual and some figures in the service manual show the control block upside down. The parts you have listed are for the control valve (plunger VT2981) not the release valve (plunger VT3096). The control valve has lift pressure when the draft arms are actually moving up, other than that the pressure is only back pressure. The release valve never sees anything other than back press on the seal side of the plunger. When the lever is in the raise position, pump pressure is applied from the control valve to the piston via the lift check valve (plug on the bottom of the control block, see VT2988) and only that pressure required to overcome the resistance of the draft arms and any weight thereon. When the lever is moved to neutral, the control valve bypasses the pump pressure back to the torque tube sump. The piston is held in a hydraulic lock between the lift check valve and the valve side of the release valve so now the entire control block is only under back pressure except for the drilled passages into the lift check valve and the valve side of the release valve. When the lever is moved to lower position, the draft arms drop and the entire control block is only under back pressure and the same when you move the lever to the neutral position. There are no provision for checking back pressure unless you want to tee in some fittings for a gauge. In any event it will be 10 psi or less. Assuming the torque tube sump is relatively clean (not loaded with a bunch of grease), the only thing that can influence the back pressure is the return oil tubing between the control block and the torque tube housing, the return oil filter in the torque tube, and the breather mounted on the top of the torque tube housing. The pump pressure is checked by teeing into the fittings on the discharge of the pump. The relief valve is in the control block under the plug (see VT2988) between the control valve and release valve plungers. Relief valve is designed for 900 - 1000 psi, non-adjustable but that doesn't mean you can't change that setting by changing the spring, adding shims, or whatever jury-rig floats your boat. Yes there are adjustments for the valves and valve operating gear. Go to mj�s link below. Start on page G7 D13, click on the pages to enlarge for reading. You will also find shimming requirements for the rock shaft & operating lever in the previous group of pages. Joe
