SEALS FOR EAGLE HITCH
KEN INDIANA
05-11-2007 01:00:05
THA SEAL ON THE HYD. CYLINDER FOR THE EAGLE HITCH IS LEAKING AND THE CYLINDER RAM IS PITTED. I THINK I CAN DRESS UP THE RAM AND MAKE IT OK, BUT I NEED A SEAL WOULD THE DELAERS BE ABLE TO STILL GET THOSE ? OR MAYBE EVAN THE LOCAL BEARING DEALER COULD GET THIS ? THANKS FOR YOUR HELP!
Paul f
05-13-2007 07:39:44
 Re: SEALS FOR EAGLE HITCH in reply to KEN INDIANA, 05-11-2007 01:00:05
The conversion for the shaft seal O3869AB is new Case # A26758 (still available)
CR 11170
National 470045
By all means replace the piston O ring it is a standard size OD 4" ID 3-5/8" Dia 3/16"
Check your cylinder wall for corrosion/pitting...that will tear up the O ring and cause your hitch to keep settling....
JDB
05-11-2007 09:23:37
It is just a standard lip seal. Should be able to get either from dealer or local bearing place.
Since you'll have it apart anyway, may as well replace the o-ring on the piston too.
ken indiana
05-14-2007 00:58:42
 Re: SEALS FOR EAGLE HITCH in reply to JDB, 05-11-2007 09:23:37
thanks for your help you guys are awesome!!
