SC Clutch Pad
Ken Christopher
05-09-2007 07:40:24
Is there anyone that knows where I can get a replacement hand clutch pad for an SC? Also. I need to pull the Clutch pulley on it. Are there any tricks to getting the nut off while keeping the wheel from spinning (I am using hand tools). Will I need to use a puller to pull the wheel off the shaft, or will it slide off?
C. Amick
05-09-2007 09:05:05
 Re: SC Clutch Pad in reply to Ken Christopherson, 05-09-2007 07:40:24
Do you just need the brake lining or the whole assembly? I got mine relined at an automotive brake shop. They just bent a piece of brake lining to fit. If you put the belt pulley and tractor in gear and set the brakes on the tractor, the nut should come off. I've not had to use a puller on any that I have removed.
