carb problems On case 430 I think
kdok44
05-08-2007 19:30:15
hi me again lol im making progress fixing the case 430 gas.. After all new ignition parts it is running so i know its not the coil plugs points condenser wires distrib cap thats all new. The problem is it will run really well as long as im only idleing and the choke has to be about half out and the throttle set quite slow. As soon as i push the choke in or speed up the throttle it wants to die. I can drive it too but only on slow throttle and being choked this seems really strange the fuel line seems good i can blow threw it all the way to sediment bowl no prob and the carb seems to be good anyone have any ideas slowly but surely its coming together thankfully with help from many of you.. Have a good day
Walt Davies
05-09-2007 14:35:41
 Re: carb problems On case 430 I think in reply to kdok44, 05-08-2007 19:30:15
either the main jet is plugged not adjusted correctly or Float needs to be adjusted or you have fuel blockage someplace from the tank to the carb.
Walt
630crazy
05-09-2007 13:41:39
Have you checked from the sediment bowl to the tank? Take the bowl off and turn the petcock on. You should have fuel pouring out, NOT just a trickle. Also check you screen and make sure it"s not pluged up.
