VAC Hyd questions
Tom/Idaho
05-07-2007 15:19:13
I checked the vent line as suggested by Sam#3 and as luck would have it ,no oil.. I took everything off except the depth control valve. It appears oil is leaking from the rock shaft down the rock shaft housing and possibly from the seal on the left "push button". The right "push button" on the depth control valve does not have a seal.
I can order and change the seal on the depth control valve but only want to do this once. As I didn't find any oil in the line that Sam#3 suggested I would think that the piston seals in the lift cylinder are okay. But, I want to change them to see if the oil down the rockshaft stops. Are there any special tips to change what appears to be "O" rings on the piston in the lift cylinder? It kinda looks like a straight forward job.
Can I run it with the depth control valve 'exposed' to make sure on the leak or will the two "push buttons" come out of the valve and spray oil everywhere?
Any assistance will be appreciated. Tom/Idaho
Joe (Wa)
05-07-2007 22:55:31
 Re: VAC Hyd questions in reply to Tom/Idaho, 05-07-2007 15:19:13
The aft plunger (w/seal)is the release valve the fwd plunger (w/o seal)is the control valve. You can operate the lift only if the back cover is mounted on the rock shaft housing & the valve actuating lever is in place over the plungers.
A leaking release valve seal is sometimes caused by back pressure, check that the oil return filter in the torque tube is not plugged.
Oil can only leak out the rock shaft when the piston seal leaks-bye. Do your piston seal leak check again, you almost always get some grease and oil on the first few cycles unless the rock shaft housing vent is plugged with hard grease. Put you finger over the opening while cycling the lift, should have slight air pressure as draft arms raise & slight vacuum as they lower. Also check the vent tubing clear back into the torque tube.
Piston seal will be either a cup or 2 o-rings. Change to o-rings was sometime in '50 but don't count on that, eyeball it. O-ring replacement is straight forward. Cup type can be a little ornery, post back someone will tell you how to do it if necessary.
Joe
Sam#3
05-07-2007 20:11:48
Tom,
The 'depth control' or lift valve uses an o-ring. The lift valve is made of several parts including a vt-2981 plunger, vt-2985 spring, v-20206 spacer(s), vt-2983 o-ring, and vt-5469 valve. These are the old part #s. The o-ring is inside the plunger and fits over the valve.
Do you have a parts catalog? Well worth the twenty dollars if you're going to do a lot of repair work. My cylinder has a cup but no biggie to change.
Good luck, Sam
