sc I think
willej
05-07-2007 13:07:35
this tractor is going to be sold for junk, and I'm thinking about trying to buy and restore it.
All I know for sure is that it is on LP gas, would it be better to leave it on LP or convert to gasoline? also is there a good source for parts?
cperkins
08-26-2007 17:42:03
 Re: sc I think in reply to willej, 05-07-2007 13:07:35
I don't know about the Dc but on LP Deeres you can convert them over to gas and use the LP tank as a gas tank and add a carb. then you have high power puller you will need to run race fuel in it but it will have loads of power
C. Amick
05-07-2007 19:13:37
I don't think they made any SC propane tractors? Could it be a DC? Is the front grill sheet metal or cast iron (DC)? The propane heads are usually pretty valuable to tractor pullers. Yes, you can get parts.
willej
05-08-2007 09:28:43
 Re: sc I think in reply to C. Amick, 05-07-2007 19:13:37
probably a D C I did'nt know propane had a different serial. tractor has been setting a while outside, are parts available to restore the propane stuff? and why is the head valuable to pullers? bigger valves or smaller combustion chambers? how difficult are parts to come by for this tractor? would it be worth my time? I had an allis chalmers in mind, but this tractor looks pretty neat .
C. Amick
05-08-2007 10:14:22
 Re: sc I think in reply to willej, 05-08-2007 09:28:43
The propane DC's are becoming fairly rare. I figure the propane head alone is worth around $300. I think the propane heads are higher compression and they put them on gasoline engines. I would keep it as a propane tractor. Most engine parts are available as new reproduction parts. New parts are expensive, though. A piston and sleeve set is around $700. There are usually quite a few used parts up for auction on Ebay. Does it still have the propane pressure regulator on it?
willej
05-08-2007 10:44:58
 Re: sc I think in reply to C. Amick, 05-08-2007 10:14:22
I LOOKED AT IT OVER A FENCE ROW, WITH LOTS OF WEEDS AROUND IT, BUT I'M PRETTY SURE IT IS A COMPLETE TRACTOR. I WAS TOLD THE BLOCK IS CRACKED.
