3-point leak
Rob Gest
05-06-2007 08:03:03
All of the sudden I started to get a leak around the two arms on my 3-point whenever I had my blade in the air. I also noticed fluid coming from the filter under my seat as well(with a load on the 3-point). I have the Case 530CK
What could be wrong? I don't just want to go in without an idea of what to look for.
Thanks,
Robert Gest
JGarner
05-07-2007 05:53:17
 Re: 3-point leak in reply to Rob Gest, 05-06-2007 08:03:03
Check your hydraulic fluid level. You will find that you are very low. The piston seals on the internal lift cylinder have failed and you are leaking hydraulic fluid into the differential case. Remove the big hex head dip stick, top right side under your seat cushion, you will see that it is overflowing.
The only fix is to drain the differential, pull the seat and differential cover off, take the piston out and replace the piston seals. I haven't had to do this on my 630 (big sister to your 530)but I hear getting the seals back in the piston bore is a real bear.
Ideas for reassembly anyone? I think 630crazy has done this on his 630, lets see if he responds. If doesn't post the question to him on this forum, he reads this regularly.
Rob Gest
05-08-2007 17:17:54
 Re: 3-point leak in reply to JGarner, 05-07-2007 05:53:17
Thanks for the help. I tore into it and am doing Ok so far.
JGarner
05-08-2007 19:44:02
 Re: 3-point leak in reply to Rob Gest, 05-08-2007 17:17:54
Do you a parts manual or Case dealer service manual on the 3 pt system? I have a parts list with exploded pictorial break down that may help if you need it. Send e-mail and I can scan and send pdf files. I have turned my e-mail on.
