six volt regulator
klyant
05-05-2007 09:07:51
Does any one know where I can buy a 6 volt regulator for my 1948 Case SC?
DurangoCase
05-07-2007 10:34:38
 Re: six volt regulator in reply to klyant, 05-05-2007 09:07:51
Auto-Lite TC-4327-E crosses to a "Standard Ignition" VR-224. Around $24 at Napa here.
SDLars
05-07-2007 17:47:01
 Re: six volt regulator in reply to DurangoCase, 05-07-2007 10:34:38
I've had the Standard Ignition item on order from NAPA since I posted a similar question about a month ago - nothing yet. It is on back order from the factory. Today I checked with two other parts stores and got the same response. Carquest told me that they would have it in about a week. We'll see. I had a line on some NOS Autolite regulators but I couldn't get them below $90 nor could I get a photo of the item to make sure I was buying what I wanted. I'd sure like to hear if someone else is able to get better results. Otherwise, I'm told a regulator that will match the generator's 12-15amp output will work. How about a regulator for a 60's vintage VW (before they switched to 12 volt)?
DurangoCase
05-07-2007 18:14:49
 Re: six volt regulator in reply to SDLars, 05-07-2007 17:47:01
I think many will work if hooked up correctly. The main difference is in the size shape and layout of the wire tabs. If you look at the one Werner sells, it has three tabs out the side instead of one and a generic mount. If you are wanting an original look, then VR-224 is same size, same mounting hole locations. I'll check what my NAPA can get.
SDLars
05-08-2007 13:49:16
 Re: six volt regulator in reply to DurangoCase, 05-07-2007 18:14:49
Yeah, I keep hoping I can find one that is like the original. I sure appreciate the help. I have three generators up and running but only one regulator and that's the original Autolite type. I know I'm going ot need a few more before I get all my "flambeau herd" finished! I'm curious to hear what your NAPA guy says.
Lee Aanderud
05-06-2007 09:39:44
I bought one for my '41 Case Model S from this guy.
Lee
flying belgian
05-06-2007 06:01:07
have them tweek the regulator up to 8 volts and then go to T.S.C. and buy a 8 volt battery. Nothing else needs to be changed and you will be surprised at how fast that thing will spin over. all them old generators put out about 10 volts.
klyant
05-06-2007 07:20:27
 Re: six volt regulator in reply to flying belgian, 05-06-2007 06:01:07
My tractor cranks over really good on six volts.I replaced all the cables with new new ones I made from welding cable.It also has a new starter switch. I played with my regulator more last night.I grounded the feild wire and it would charge 7 volts. Cleaned it repolarized it.Now it charges, but as rusty as it is I don't think it will last long. The amp meter ups all over from 5 to 20 amps.
C. Amick
05-05-2007 18:57:02
I buy mine from a local automobile electric shop. You need to match the voltage regulator to the generator that you have. You will need to give them the number off the generator to make sure you get the correct one.
M5G
05-05-2007 18:16:18
Try your local auto parts store: Napa, ORiely etc they will have them in stock...reasonable.
amo
05-05-2007 16:43:47
go to parts to the left and look up case. sc electrical parts
klyant
05-05-2007 17:13:44
 Re: six volt regulator in reply to amo, 05-05-2007 16:43:47
The only thing that I can find is a voltage cutout. My tractor has a voltage regulator
