SC TEARDOWN (AGAIN)
KEN CHRISTOPHER
05-05-2007 06:36:24
WELL, GO THE SC TORE DOWN TO THE FRONT PEDESTAL, BLOCK, AND TRANNY LAST NIGHT. I WAS GOING TO PULL THE ENGINE, BUT I DON'T KNOW IF I NEED TO. MY PROBLEM WAS MY COOLANT WAS MIXING WITH THE OIL, BUT NOT VICE VERSA. I THINK IT IS THE O-RINGS BETWEEN THE CYLINDERS AND THE BLOCK. THERE IS A PATCH ON THE LEFT (BEHIND THE CARB) OF THE BLOCK-OF WHICH I HOPE HAS NOTHING TO DO WITH IT. I HAVE TAKEN THIS PATCH OFF, BUT IT LOOKS LIKE A BIG SCORE UNDERNEATH (MAYBE JB WELD?) THEN OF COURSE THE PATCH IS ATTATCHED BY 100 LITTLE SQUARE HEAD BOLTS OF WHICH GO ALL THE WAY INTO THE BLOCK. I BELIEVE THE TOP HALF ARE IN THE WATER JACKET, AND THE BOTTOM HALF ARE IN THE CRANKCASE. I WANT TO KEEP THE BLOCK, BUT DON'T KNOW IF IT IS FIXABLE. I WAS THINKING JBWELD THE WHOLE AREA, BUT I AM NOT SURE IF A GUY CAN GRIND THE STUFF AFTER IT HAS CURED TO SHAPE IT LIKE THE METAL. DOES ANYONE KNOW WHERE I CAN GET A SLEEVE PULLER? ANYONE EVER HAD THEIR BLOCK BOILED?
CHinNY
05-06-2007 11:31:23
 Re: SC TEARDOWN (AGAIN) in reply to KEN CHRISTOPHERSON, 05-05-2007 06:36:24
Just wanted to say hi cousin! Ed Christopherson from Palmyra NY
C. Amick
05-05-2007 18:53:47
Try some block sealer to seal around the sleeves before you go tearing things apart. I have a block that is cracked. It was repaired using a combination of welding and J.B Weld. The J.B. Weld was used to fill in the voids missed by the welding before grinding it down.
J Heitkemper
05-05-2007 14:36:24
Tough break .. Had similar problem with DC ,,Believe Me , You will be headaches ahead if you simply get another block ,,. Here in Southern In , I have a good block with no ring wear in a 42, needed the head last year for my 54 Sc , Will let her go to a good home cheap Let me know if you want it,m, Thanx Jim
Ken Christopherson
05-05-2007 17:18:55
 Re: SC TEARDOWN (AGAIN) in reply to J Heitkemper , 05-05-2007 14:36:24
Engine is complete minus the head? How much? I am not sure how I would come pick it up. Right now I am kinda in the teardown stages. Wasn't planning on dropping hundreds of dollars. The only drawback is that this motor is the original. #'s match and everything. Thats why I would want to salvage it. But if it's not worth it, then, it's not worth it.
charles hess
05-05-2007 11:10:14
Sounds like it was frozen sometime in its life an had major surgery an is not working. Dont know what you have in store for it as far as use is concerned but if you are going to use it a used block would be way to go. Lots of them on Ebay. If just going to set around try someBars leak-have used it for50 yrs an in fact put it in sc i just re did for security.Otherwise remove oil pan an you should be able to see where antifreese is seeping-im betting it is from frozen block which seeme to be a major crack that someone attemped to repair.If oring on cyl or crack Bars will probably seal . You can also try to seal as you said if leaking from crack.If you still have motor on tractor you can put wlde block of steel or wood om bottom ow cyl an push up with jack or get or make puller keping in mind sleves will crack easily if pressure is put in i narrow spot.
KEN CHRISTOPHERSON
05-05-2007 13:04:20
 Re: SC TEARDOWN (AGAIN) in reply to charles hess, 05-05-2007 11:10:14
IS THERE ANYONE THAT MAKES A OVERHAUL KIT FOR THESE. I CAN'T FIND ONE ON YT. SLEEVES/MAIN BEARINGS/ CONNECTING ROD BEARINGS/ COMPLETE ENGINE GASKET KIT. WATER PUMP REBUILD KITS? THERE AREN'T ANY COMPANIES THAT MAKE A SLEEVE PULLER AROUND? WHERE CAN I GET THE "BAR" YOU ARE REFERRING TO TO FIX THE CRACK?
charles hess
05-05-2007 13:25:54
 Re: SC TEARDOWN (AGAIN) in reply to KEN CHRISTOPHERSON, 05-05-2007 13:04:20
Bars leak at any auto store Napa-AutoZone,PepBoys ect will have it.John Saeli who posts on here can fix you up with all that other stuff. [email protected],com
