VAC hyd oil
Tom/Idaho
05-05-2007 05:34:08
I have an owners manual coming but was wondering how you can tell when it's full. I know it holds about 2 gallons (found that in the archives as well as other useful information) and I can see the oil once I remove the plug. It has a leak on the control valve that I am going to fix so I know it needs some oil. Thanks, Tom/Idaho
Sam#3
05-05-2007 06:20:27
 Re: VAC hyd oil in reply to Tom/Idaho, 05-05-2007 05:34:08
Fill to the hole. Are you sure it's leaking at the control box? IF the cup/o-ring in the cylinder leaks the oil runs into the rockshaft housing and will then drain onto the box making it appear to leak. You can check for oil in the housing by loosing the small vent line on the lower right of the housing. If there is oil there I'd suspect the cylinder.
Tom/Idaho
05-05-2007 13:05:01
 Re: VAC hyd oil in reply to Sam#3, 05-05-2007 06:20:27
Thanks for the tip. I will fill it with oil, run it and try and see where it is coming from. Thanks again, Tom/Idaho
