problem starting case 430
kdok44
05-04-2007 21:57:36
hi im having trouble getting my tractor to start a case 430 gas. I changed the points and condenser and it wont run now barely even fire ever.. The spark plugs are sparking maybe weak. the engine has compression not sure how much but if you put your hand over the carm it sucks really hard and it is fairly hard to turn over by hand. the carb seems to be working gas gets to cylinders. The sparkplug wires are in the correct order and the number one pistion at top dead center lines up with tht rotor so it should be in time correct. MY Question is does anyone have any ideas why its not working ONE day worked great next day nothing. Any help would be gratefully listened to thanks...
Richard Chambers
05-06-2007 20:17:15
 Re: problem starting case 430 in reply to kdok44, 05-04-2007 21:57:36
I have a 430 Butane, It could be the coil or a coil wire. When the problem is intermittent I would lean toward a bad connection in a wire.
My suggestion is to start the tractor on a dark night with no lights and look for sparks.
kdok44
05-06-2007 10:02:13
Hi guys thanks for all the info. I finally got it going lastnight after changeing all the wire plugs ect it still wouldnt start i had great spark think i had a little piston was squirted a little oil in the spark plug holes cranked away and it finally started and ran goood I thought i Had the problem totally fixed so i left it alone. in the morning i had to move a bale started first Crank better then normal let it warm up it worked fine. then as i was headed back to the garage it began to die on me. If i pushed in the clutch it would run and i had to pull the choke full out.. Then take clutch off and go about 100 feet and limp back to garage. I shut it off let it cool down started it easy let it get hot and it does it again... seems when i leave it get hot NOT over hot. Then it wants to die on me... Anyone have any ideas whats wrong now lol i ll check to see if i got the wire on right AND your right it is 1342 wow how did i manage that i read it 100 times in my repair book brain freeze maybe thats all that it is firing in wrong sequence does that sound correct Thanks again everyone
Thunderr
05-05-2007 19:03:12
Ummm firing order on that machine is 1-3-4-2, not 1-4-3-2. but in good working order i think you might have a little better luck than you are having. LOL My 430 a year old than yours was running with one spark plug removed haha. Someone got in rush to move inside before he got rained on...
Ken L.
05-05-2007 17:13:29
You say it ran good one day and not the next. Did you start having problems before you changed the points & condenser or after. If it was after, did you set the points correctly? It's also possible that the new condenser is bad. Make sure that you didn't forget to screw the wire from the condenser to the points or pinch the wire and short it.
630crazy
05-05-2007 15:40:19
How old is your gas? Might be a combination of little things.
kdok44
05-05-2007 17:12:33
 Re: problem starting case 430 in reply to 630crazy, 05-05-2007 15:40:19
hi its a 69 but in good condition i bought all new ignition parts condenser distributar cap rotor wires plugs.. put that all on and still wont fire. Im pretty sure i got the wires on correct 1432 is the order and thats how i have them on the distributar cap. The only thing i didnt do is the coil but the sparks are getting a good spark now. and i checked the timing according to the timing mark 4 deg before topdead center it lined up and it was at top dead so the timing should be good IM stumpedd... anyone ever had similar
TimBinWV
05-05-2007 06:11:19
If you had all the plugwires off at the same time,there's a chance you got them back on in the wrong rotation. correct sequence,wrong direction will let it fire on 2 cylinders,I think...something to look for...Good Luck.
bradley martin
05-05-2007 02:46:36
Probably a cracked coil.
BarryfromIA
05-05-2007 19:12:31
 Re: problem starting case 430 in reply to bradley martin, 05-05-2007 02:46:36
Check the rotation of the rotor in the distributer. Then check the firing order of the wires with reference the the rotor. It could happen.
TimBinWV
05-06-2007 05:05:51
 Re: problem starting case 430 in reply to BarryfromIA, 05-05-2007 19:12:31
That's what I was saying,just not so eloquently!
BarryfromIA
05-06-2007 19:21:32
 Re: problem starting case 430 in reply to TimBinWV, 05-06-2007 05:05:51
My 311b would not fire at all when I did that. But it was an easy fix after I thought about it and checked.
