1070 problems
curt mcnitt
05-04-2007 14:23:58
I have a case 1070 that i have recently had a clutch and a new hydrolic pump done to it. I just got it back from the mechanic and ran it for a couple of hours and now i have no reverse or first gear power shift.
dwag
05-05-2007 05:21:57
 Re: 1070 problems in reply to curt mcnitt, 05-04-2007 14:23:58
Do you have 2nd or 3rd powershift? (hang onto your hat when you try 3rd)
curt mcnitt
05-05-2007 06:33:06
 Re: 1070 problems in reply to dwag, 05-05-2007 05:21:57
yes, I can start the tractor in neutral, with the clutch in but if i try to release the clutch in reverse or 1st gear power shift while still in neutral it will stall the tractor. if i put it into gear than i can go if i put it in 2nd or 3rd powershift in all gears.
Eagle Doc
05-05-2007 16:57:23
 Re: 1070 problems in reply to curt mcnitt, 05-05-2007 06:33:06
Probably the C-3 pilot spool in the control valve is stuck.
