Pulling Injectors 188D - Tips, tricks or Tools?
Jon (IN)
05-04-2007 06:11:15
Getting ready to pull the injectors from my 1973 Case 350 Track loader with 188 Diesel engine. How difficult are these to get out? Anyone have any tips or tricks to getting these out? Any special tools needed?
Thanks,
Jon
Walt Davies
05-05-2007 21:50:14
 Re: Pulling Injectors 188D - Tips, tricks or Tools in reply to Jon (IN), 05-04-2007 06:11:15
Try a rolling head bar they work great for things like this. they come in different sizes so get one that fits.
Walt
edj856
05-04-2007 09:30:56
I pulled injectors on Case 580 backhoe with 188D and don"t remember using using anything other than a prybar. Just be careful not to bend anything. The hard part is installing the new injector seals. I put them in some very hot water before installing them. Anyone else know a better way to install the seals?
george md
05-05-2007 16:28:56
 Re: Pulling Injectors 188D - Tips, tricks or Tools in reply to edj856, 05-04-2007 09:30:56
edj,
The tool to put them on is cheap , I got one at a cat dealer some years ago and it was 50 cents then . Probably the only low priced item they ever sold. I would think a fuel shop should have them . It is nothing but a tapered piece of plastic with a slight cut out to clear the nozzle.
george
TomVAC
05-04-2007 12:06:26
Two pry bars should work. I'm sure there is some kind of slide hammer type puller but the dealer I worked at was too cheap to have something like that. As far as a seal tool we used to use one that was shaped like a bullet. The o.d. was the same size as injector and fit up to the bottem. It was tapered to a smaller diameter so the seal could be started on it and gradually expanded to the bigger size and slide right on to the injector.
