Case plow shear bolts?
Kelly MT
05-03-2007 21:29:03
I"m using an old Case 6 bottom pull behind plow and wounder what type of shear bolt is required. It uses a 3/4" bolt. One is a pivot, two others are retainer bolts. I can"t read the model number, It"s gone. The colors on the plow are tan, orange and green. Thanks for any info, PK.
bradley martin
05-06-2007 18:04:05
 Re: Case plow shear bolts? in reply to Kelly MT, 05-03-2007 21:29:03
I was thinking about your plow while in the field today and recalled seeing in the old parts book and /or sales brochure that another option on those plows was an oak pin in the hitch...if you had few stones it was a cheap way to protect the plow.
bradley martin
05-05-2007 19:25:59
It is likely an "A" or a CH model. I don't believe it would use a 3/4 " shear bolt. Are you sure it is shear bolt protected or is it a spring loaded trip hitch?
Kelly MT
05-06-2007 21:52:34
 Re: Case plow shear bolts? in reply to bradley martin, 05-05-2007 19:25:59
You might be right, I'm just guessing. It looks like the beam will swing back from the top bolt. Looking at the Case logo I can see what looks like a C right after the Case name. As far as the hitch goes, it's been modified/repaired several times. I'll start scratching around and see if I can find a picture of the models you named. Thanks, PK.
bradley martin
05-07-2007 02:24:08
 Re: Case plow shear bolts? in reply to Kelly MT, 05-06-2007 21:52:34
If you could post a picture, I am sure myself or someone on this great forum could identify the plow and the mechanism. A 3/4"bolt requires over l00,000 lbs to shear.
