VAC Engine Bearings
Glenn FitzGeral
05-03-2007 15:29:55
My VAC14 has low oil pressure. It will be a while before I get to working on it....maybe a year. I understand rod, main, and cam bearings are currently readilly available at Checker Auto Parts, etc. I'm not sure I need new bearings, but I wouldn't be surprised. Do you suppose they will still be available a year from now? I'd go ahead and buy a set now, but without tearing down the engine, I don't know what size I'll need, and I really don't care to have it all torn apart before I'm ready to put it back together.
Thanks,
Glenn F.
mj
05-03-2007 19:07:11
 Re: VAC Engine Bearings in reply to Glenn FitzGerald, 05-03-2007 15:29:55
third party image
What is it showing on the gauge? 12-20 is spec. If you have 10 or so and want more, drop the pan and pull the oil pump. Stretch the bypass spring until the free length measures 1 15/16". The springs lose a bit over time and this will usually bring back the pressure.
Glenn F.
05-04-2007 13:31:17
 Re: VAC Engine Bearings in reply to mj, 05-03-2007 19:07:11
I have not had a chance to work on the little tractor in the 3-4 weeks since I bought it. It runs smooth and quiet, but does not register any oil pressure on the gauge. I removed the line from the gauge when the tractor was running and oil flowed out but not with much force. When I get a chance to work on it I plan on installing a known working gauge, remove the valve cover, start it up, and see what I have.
Glenn
mj
05-08-2007 07:07:50
 Re: VAC Engine Bearings in reply to Glenn F., 05-04-2007 13:31:17
I've had some that were slipping the drive gear (in the oil pump) on the shaft that gave the symptoms you describe. The half moon key gets worn and in turn wears the gear and shaft. I fixed one by using a soft key out of position and pressing the gear onto the shaft. The gear is no longer free to move on the shaft but doesn't seem to matter. With that done and the spring stretched back to a bit over spec I'm getting 18+ psi at cold idle on that tractor.
geomo
05-07-2007 05:39:45
I would try another gauge before I did anything.
I agree you will not know bearing size without tearing down.
El Toro
05-03-2007 18:25:17
I wouldn't buy any parts until you get the engine torn down. The crankshaft may need to be ground undersize. Your local auto machine shop can measure it and determine what needs to be done. It may only need to be polished and they can get all the bearings for your engine. I would check that oil pump to make sure there's no sludge blocking the pickup screen. The pump may be getting worn too. Hal
Paul f
05-03-2007 16:55:29
Before you tear into it remember VACs do not generate much oil pressure 12 lbs is not bad...
amo
05-03-2007 15:40:31
wait until you tear it apart, they might be different than what was original. You can go to a plsce that deals in bearings and thay can be found at reasonable rates. Good luck.
