Case 580C transmission problems
Garry McSwain
05-03-2007 09:05:55
I have a Case 580C Backhoe. I was using it recently to clear some small sapling and vines from a piece of land. I noticed going up a slight incline that the tractor had a hard time pulling up the incline. When I finished and started back to the shed the tractor stopped moving. The engine was running fine but I lost forward and reverve movement at the same time.
It has a Power Shuttle with a torque converter. When I checked the transmission oil level it was a little low. After adding fluid it still won't move in forward or reverse. Any ideas on what it could be? You don't have to split the tractor to remove/rebuilt to power shuttle do you? Thanks.
dwag
05-03-2007 16:52:31
 Re: Case 580C transmission problems in reply to Garry McSwain, 05-03-2007 09:05:55
Might check a couple pressures. 580C"s were a dream to work on. Shuttle can be dropped down and rebuilt in a day,no split needed. Get a shop manual or use parts schematic on caseparts.com
