S hand clutch
36 A
05-01-2007 19:37:18
The hand clutch lever won"t stay in the lock possion.We adjusted the clutch and it feels good but it will still pop back if you jab it some it will hold.
bradley martin
05-03-2007 03:23:19
 Re: S hand clutch in reply to 36 A, 05-01-2007 19:37:18
Assuming the clutch is adjusted properly, you need to check your linkages..both outside and within the bell housing. If outside linkage is OK, you will have to access the overcenter throwout mechanism...it is possible that one of the three arms is broke or more likely the pin has fallen out, preventing the mechanism from going over center,
