need to replace case 1816 motor
jayc
05-01-2007 08:28:12
What is the best replacement motor for this skidsteer.Can't find a motor with the same shaft size.Don't know what to do!
steven meckstroth
05-01-2007 14:36:16
 Re: need to replace case 1816 motor in reply to jayc, 05-01-2007 08:28:12
I put a 20HP Honda V-twin in one. Have to make a few modifications to make it work.
jayc
05-01-2007 19:57:49
 Re: need to replace case 1816 motor in reply to steven meckstroth, 05-01-2007 14:36:16
Thanks for your reply.What kind of modifications did you make?Any help would be most appreciated,especially on making the shaft workable.Can"t find any motor with the old shaft size.Thanks!
IA Roy
05-01-2007 10:20:34
I think there was a story in the latest Farm Show magazine, where they replaced the engine with a Briggs and Stratton Vangard. Had a machinist make an adapter coupling to address the shaft differences.
jayc
05-01-2007 20:02:51
 Re: need to replace case 1816 motor in reply to IA Roy, 05-01-2007 10:20:34
Sorry I don't read the farm mag.,so what size briggs and model did you install?What was the shaft size on the Briggs.Thank you so much for your imformational help on this.
IA Roy
05-01-2007 20:14:23
 Re: need to replace case 1816 motor in reply to jayc, 05-01-2007 20:02:51
He replaced a 16 HP Tecumseh witha B&S Vanguard 18 HP. Said the Tec had a 1 1/8" shaft and the Briggs had a 1" shaft. He had a machinist make an adapter. He said he had to remove the backup recoil starter to make clearance for the oil cooler
Will- Tx.-Mn.
05-01-2007 09:10:14
jayc,
If you are interested in a trade,I have a stand on skid steer that works fine,I am in Texas,and where are you?
~Will
jayc
05-01-2007 20:10:17
 Re: need to replace case 1816 motor in reply to Will- Tx.-Mn., 05-01-2007 09:10:14
I have a great skid,I just need to replace a obsolete motor.This skid had its original motor up to now.Just looking for a new fit.Thanks for replying!
