870 case steering
jddeere
04-30-2007 18:55:38
have an 870 case that you can turn real sharp to one side and the other side doesnt turn nearly as sharp. is this normal?
JHH
04-30-2007 20:13:52
 Re: 870 case steering in reply to jddeere, 04-30-2007 18:55:38
No not normal. Check that the pedestal in the center is centered when the wheels are straight ahead. If not the tie rods can be adjusted so that it is centered. Also there are stops cast on the center that the pedestal get against when turned the whole way. If one of these is broken off it may let it turn shorter that way. I can post pic if you need.
