Rebuilding Hydraulic cylinders for fron loader, CA
Wison-CASE
04-30-2007 17:58:45
I have read that hydraulic cylinders can be rebuild by purchasing stainless tube, instering on the cylinder body and making a new rod from chromed rod to fit as the old one.
Does any one have details on the procedure and a source to buy the material.
I am a retired machine operator and have lathe at home that cold possible produce the 4 cylinders needed for my front end loader. Right noow the leak, shafts are all bunged up and no chrome left on the shafts if they ever had it.
It is an old CASE SI from the 50"s, and myslef beeing retired lieaves me with more time than money. I use it in Ontario-Canada to get my logs onto the portable saw mill.
Anyone willing to share?
Thanks, Wilson
Keith-OR
05-03-2007 08:43:50
 Re: Rebuilding Hydraulic cylinders for fron loader in reply to Wison-CASE, 04-30-2007 17:58:45
Not to be disrespectful to anyone, But did anyone really bother to read and understand what Wilson is asking?? Said he is retired and a machinist with lots of time AND limited funds!!..:>(
I rebuilt all the hydraulic cylinders on my old Warner & Swasey bachhoe couple of years ago with less than $25 in each cylinder. Where as new cylinders (if I could find to fit) would have been $300 to $400+ ea. Big difference in price for a small amount of time it took to repair.
Really, what is so hard about rebuilding hydraulic cylinders? All that there is to them is a shaft with piston on the end, which has couple of seals,(2 if double acting)a wiper and then seal and wiper on the end of cylinder.
Wilson , just take one of your cylinders apart, mic shaft and take piston to your local hydraulic shop. Usually they can match up the seals with newer type or supply you with new piston. Go to machine shop and see if they have or can get the chrome shaft for you.HTH
Keith & Shawn
bradley martin
05-01-2007 05:35:18
You would likely be able to purchase new cylinders from any farm /hydraulic supply source cheaper than sourcing small quantities of the various components....particularly if you value your time.
watsonsgotit
04-30-2007 18:30:09
Nothing against what you are trying to accomplish, but you could probably find another tractor such as a SI with a loader cheaper than you could rebuild the cyclinders on your loader.
cj3b_jeep
05-01-2007 05:59:03
 Re: Rebuilding Hydraulic cylinders for fron loader in reply to watsonsgotit, 04-30-2007 18:30:09
I've heard it's only about $100 to get a cylinder rebuilt. Is that right or do they cost a bunch more?
watsonsgotit
05-01-2007 16:12:59
 Re: Rebuilding Hydraulic cylinders for fron loader in reply to cj3b_jeep, 05-01-2007 05:59:03
Cost depends on what has to be done. If you start replacing shafts, you can spend $1000 very quickly on each cyclinder.
Wison-Case
05-02-2007 06:02:29
 Re: Rebuilding Hydraulic cylinders for fron loader in reply to watsonsgotit, 05-01-2007 16:12:59
I appreciate the comments and most probably are right in terms of cost if I had it done by a shop. The elements missing from the respondents is that I am a machinist and even that I never opened a hydarulic cylinder I am sure I can do it if someone else can. I have lathe and other miscel. machine shop equipment as well as many years of expenrience on precision machinist.
The other is that my time is basically free to me since I do not have mayor comitments and love to work on kachining projects.
What I am missing is:
1-Where to buy the RAW MATERIAL
2-Process involved with specific detail so I do not re-invent the wheel.
At this point I know I can take the existing shaft and grind just a bit and have it re-chromed.
I can probably make new piston at very little cost to me.
Missisng is the comparison verus buying chromed rod (and where) and stainless sleeves (if needed) for the cylinders.
Thanks again to all thos that took the time to respond to my question, but if it can be done, I can do it.
Wilson
