Head oil passage
INCase
04-30-2007 06:47:28
Getting ready to change the head(s) on the 800. Will put on new head gaskets. Did they still use O-rings for the oil passage and is there more than one? I only see one on the head that feeds the rocker arm. Is there another? Thanks.
Jim from Calif
04-30-2007 13:31:18
 Re: Case 800 head o-rings in reply to INCase, 04-30-2007 06:47:28
Both the gas & diesel heads each have 3 O-rings. These O-rings seal the drilled oil passages from the engine block to the cylinder head that provide lubricating oil to the rocker arm assemblies and the exhaust valve push rod openings in the head & block...
