Parking brake on CASE SI tractor with front loader
Wison-CASE
04-30-2007 04:24:13
I tought I posted these a couple days ago, but somehow I guffed... here it goes again:
I cannot find where is the parking brake for my recently acquired CASE SI tractor with front loader (old machine built around 1950). Evey time I load a log and need to adjust the camalongs for leveling the load I need to stop the engine, go and adjust in the front, then re-start again and move.
Can anyone help. I purchased the manual for it, but will take a couple weeks to get to my place in Canada.
Thanks, Wilson
dsmoker
04-30-2007 06:04:45
 Re: Parking brake on CASE SI tractor with front lo in reply to Wison-CASE, 04-30-2007 04:24:13
There should be a ratchet type latch to hold the inside pedal down and a pin to lock both pedals together. If your system is still all there, you pull a little rod on the rear of the RH platform behind your foot, and that flips the ratchet piece forward to hold the pedal down. Pretty good chance most of it is gone though.
