VAC Case PTO
Howard H.
04-29-2007 19:49:17
I was mowing around the folk's place this afternoon with the VAC - everything was good for a while, until the PTO starting slipping out of gear.
The pull-up handle was staying put at first (and for the months I've had the tractor), but I had to wire it in place to finish...
Is that common?? Or has something turned loose inside?
Thanks for any info,
Howard
WK-WA
05-01-2007 22:38:03
 Re: VAC Case PTO in reply to Howard H., 04-29-2007 19:49:17
The shaft goes through the housing, through a spring, and then through the shifter fork. The spring and fork is held in place by a roll pin. When you put the PTO in gear the roll pin sets in a saddle in the fork (locks the gear in place). The edge the roll pin slides over is worn down and allows the pin to slip and disengage. To repair remove the PTO pod (6 bolts) (drain the rear end first), Remove the roll pin, pull the shaft back to remove the fork and then use a round file and deepen the saddle. Reassemble, oil back in rear end, and you should be good to go for another 50 years.
