I need to find the special torque wrench tool for
Nicholaus Sowde
04-29-2007 17:43:43
I need to find the special torque wrench tool for my Case Vac? Does anyone know where I can find one? Thanks
cj3b_jeep
04-30-2007 11:00:52
 Re: I need to find the special torque wrench tool in reply to Nicholaus Sowder, 04-29-2007 17:43:43
If you use something offset, be sure to read the owner's manual for the torque wrench, there's a formula to overcome the extra leverage you'll be adding.
Joe (Wa)
04-30-2007 10:22:37
third party image
Cylinder head nut torque extension? 1/2" drive x 11/16" box end wrench size was Case p/n CAS1257. Photo is the same extension, Snap-on p/n S8663B.
Joe
Joe (Wa)
04-30-2007 10:45:39
 Re: home made alternative in reply to Joe (Wa), 04-30-2007 10:22:37
third party image
Photo from a "george md" post. Note that drive extension must be the same length as the driven extension (no offset).
Another alternative is the older style bending beam torque wrench. The socket wall may have to be ground down to clear the pushrod tubes.
Joe
Olddog
04-30-2007 05:22:36
Make One!!!
Take a (cheap or whatever) 9/16 and 11/16 (12 point) boxend wrench and weld a piece of steel (pipe or whatever) in between them; to form a sort of a C.
Put the 11/16 on the head nut. Hold the 9/16 centered above the head in the same position, cut the pipe to fit in between, out beyond the side of the head. The 9/16 will fit tight on the 1/2 sq drive of your torque wrench.
Roger (Mi)
04-30-2007 04:37:20
 Offset tool for head bolts. in reply to Nicholaus Sowder, 04-29-2007 17:43:43
Certain head bolts cannot be torqued properly without a special offset tool. A Snap-On or MAC tool dealer will have one.
Tom Railsback
04-30-2007 11:22:22
 Re: Offset tool for head bolts. in reply to Roger (Mi), 04-30-2007 04:37:20
I recenty tried to but a Snap-On wrench like the one in the first picture and was informed it's no longer available.
Joe (Wa)
04-30-2007 13:09:31
 Re: Offset tool for head bolts. in reply to Tom Railsback, 04-30-2007 11:22:22
I think the original Case p/n CAS1257 ext was made by OTC. I bought the Snap-on in the photo about 1999 or 2000?
The ext used to be common back when cyl heads required retorque after so many running hours and one did not want to pull the rocker arms. They were generally called "under rocker arm ext" in the marine industry.
Another option is to buy a box end ext similiar to a crowsfoot. I think most tool suppliers can give you the offset calculation or do a search, it will be avail on the net.
Joe
Larry in Mo
04-29-2007 18:35:03
If you need a regular torque wrench just about any automotive store that sells hand tools will have one. Get one calibrated in lbs/ft for general use. Lihgter applications call for lbs/inch. If your Case has a special application, and I can't think of one, then see your nearest CIH dealer. LE
