Case 930 tractor valve body
Kay31
04-29-2007 14:26:11
My Dad is having problems with his 930. Does anyone know or have the adjustment for the valve body for the 3 pt. hitch. He can"t get it working. I am trying to help him out by searching the internet. I am not having any luck. Dad just turned 79 & has been working & fixing machinery etc. for years. Anyone have any ideas please email me so I can pass it on to him. His field work awaits.
Thanks for your time.
Ken L.
04-29-2007 14:56:35
 Re: Case 930 tractor valve body in reply to Kay31, 04-29-2007 14:26:11
Do the remotes work or are they dead too? Years ago, I had problems with my 930 a couple times. Standing behind the tractor, straight up from the PTO towards the back of the fuel tank, there is a stand holding up the tank. I had to remove that stand, and in front of it,( don't remember this very well) there is a nut or a plug that I took out. I pulled everything out of the hole and down in the bottm, there was an oring that was blown. The first time it happened, I just replaced the oring. Lasted about two weeks. The second time I put gasket maker silicone on it and never had that problem again. Don't know if that's your problem or not but, I hope this helps.
midlam
04-29-2007 14:52:01
a common problem.The spool is sticking in the valve body. put a punch in the hole in the spool and thread it out then clean.
There were post a few weeks ago right here about that problem.
