Case thing's,
Kirk in Ks,
04-29-2007 12:34:15
Hi Jim,
Where does the pyrometer wire go on the left side of engine?
I see this wire hanging near the middle of engine, and it's kinked like someone unhooked it, and then left it like that,
I wanna hook it back up, but i dont know if this is the pyrometer line, or something else?
JoeBob/IN
04-29-2007 19:00:54
 Re: Case thing's, in reply to Kirk in Ks,, 04-29-2007 12:34:15
If it is a pyro wire then it is junk. They are actually calibrated wires and can't be spliced or kinked. If it is the pyro wire it will go to a probe located just past the turbo in the exhaust pipe, real easy to tell if it is that or not.
JoeBob/IN
04-29-2007 19:00:48
Walt Davies
04-29-2007 16:01:26
If you are going to be playing around connecting loose wires I strongly suggest that you get a book showing the wiring diagrams so that you don't make a big mistake and fry something including you.
Walt
