need Case info on 1958 model Backhoe/Loader
jim cramer
04-28-2007 17:14:52
can anyone tell me anything about the model number and info for a small '58 Case Backhoe/loader regarding engine type, cyl. hp . and where i could get parts for it .
This is a machine I am interested in buying for some light work around the farm -- any idea on prices ? it appearst to be in poor shape but running and moving...
Thanks-- any info would be appreciated... JIM
TimBinWV
04-29-2007 05:37:14
 Re: need Case info on 1958 model Backhoe/Loader in reply to jim cramer, 04-28-2007 17:14:52
It would help to know a little more about the tractor.If it was built on the 300 tractor, It's most likely a 148 cu.in. gas engine,if it's a '58 model. That was the most common engine used in their small backhoes. If it was built on a 200 Case ,then it could be a 124 cu. inch. I've not seen one on a 200,but I have seen one on a VAC...which has a 124. See if you can post a picture,that'd be a big help.
Joe (Wa)
04-29-2007 08:56:48
 Re: need Case info on 1958 model Backhoe/Loader in reply to TimBinWV, 04-29-2007 05:37:14
Tim, I think the 200 series had a 126 cid engine.
Joe
BarryfromIA
04-29-2007 19:18:49
 Re: need Case info on 1958 model Backhoe/Loader in reply to Joe (Wa), 04-29-2007 08:56:48
A 200b may have an engine similar to a VAC but the horsepower is closer to a 300b. I have build sheets for mine if you want know what they were from the factory.
