Leaking differential (pic)
Kestrel CT
04-28-2007 17:08:06
third party image
Good evening. Anyone out there ever fix a leaking bearing carrier on a Case VAI ? I found that gear oil is weeping out from behind the differential bearing carrier (not the oil seal itself) where it mates against the side of the differential.
Photo shows my finger pointing at the leak source. Brake cover plate and drum are removed.
My book shows only shims behind it. How is it supposed to seal ? Just torqing down the four bolts ? I sprayed 'em with Kroil to loosen 'em up overnight.
Just wondering what kind of excitement I'm in for tomorrow in addition to draining out the 7 gallons of 90 wt.
Thanks guys.
charles hess
04-29-2007 19:01:46
 Re: Leaking differential (pic) in reply to Kestrel CT, 04-28-2007 17:08:06
If they are tight i would agree to let alone.However make sure all crud is removed . make sure all hard stuff is removed around studs.It looks like some sealer was on casting in your second photo.Again clean clean clean all surfaces an than assemble an torque evenly.I suppose you could put some sealer sparangly around studs.Case has there own sealer you could use.Permatex is another.Silicone stuff i would never use.
kestrel CT
04-30-2007 17:04:13
 Re: Leaking differential (pic) in reply to charles hess, 04-29-2007 19:01:46
Much appreciate the help. I cleaned everything in sight and going to use some Permetex, then button it back up and see what happens.
charles hess
04-29-2007 06:40:13
Just shims. You might want to check studs for loosnes even remove an clean threads.Than replace using a sutiable sealer-replace shims after througly cleaning them an replace cast piece .Check shaft end play an if satisfied than carefully new seal.
Kestrel CT
04-29-2007 11:39:43
 Re: Leaking differential (pic) in reply to charles hess, 04-29-2007 06:40:13
third party image
Chas,
Any tips on removing the studs ? I double nutted them but there is no room to swing a wrench on the inside nut and back them out due to the raised lip on the housing. I suppose there is a special wrench/socket for this but its not in my tool box, not now anyway.
Perhaps they should be left alone. They seem good and tight in there. However, the 2 shims were pretty cruddy, dirty, and wet all around. Maybe that's where the leakage was.
Just hate to refill and empty the tranny any more than necessary. Any further advice appreciated !
Joe (Wa)
04-29-2007 19:52:29
 Re: Leaking differential (pic) in reply to Kestrel CT, 04-29-2007 11:39:43
You may be able to get away with just cleaning up the shims and reinstalling. I would use a sealant like #2 or #3 permatex on the shims.
Personally I would pull the studs and reseal the threads.
Doesn't look like there is enough stud to casting clearance to get a regular stud puller on the 2 back studs, takes about a 1/4" or so.
A crowsfoot and double nuts will work if the studs are not seized up in there. Any that are leaking should come out pretty easy.
Joe
Kestrel CT
04-29-2007 07:48:50
Thanks Charles.....we'll give it a try today. My rear steering support bracket also has leakage from each of the four attachment studs where they thread into the torque tube.
I might as well drain that too, remove and seal them up as well. This tractor had a loader on it before I bought it and I think she was worked hard and saw lots of stress. She's in retirement mode now except for hauling things around now and then.
TimBinWV
04-29-2007 05:40:13
There's most likely a gasket in there...
