problems starting and irregular running
George Anderson
04-28-2007 13:00:53
I have had the injector�s serviced .But still the tractor smokes sometimes the engine has a fuel knock but that clears up when the engine is under load. When the fuel tank is more than three quarter full the engine starts ok .Any theories?
charles hess
04-29-2007 07:06:57
 Re: problems starting and irregular running in reply to George Anderson, 04-28-2007 13:00:53
I am guessing as i am not familiar with tractor. But sounds like you have a supply to inj pump problem somewhere.I am thinking they have fuel tank mounter low an need fuel pumped to inj system so might have a weak pump -small hole in line letting in air as pump needs to lift fuel-or kinked line in system-fuel filter leaking.
charles hess
04-28-2007 13:53:24
What kind-model tractor/?
George Anderson
04-29-2007 01:50:41
 Re: problems starting and irregular running in reply to charles hess, 04-28-2007 13:53:24
The model is Case 895 the fuel Injection pump is Bosch .
