5140 tach not working
Colin Kent
04-28-2007 04:02:18
We have a '91 5140 w/ 7500 hrs and the tach has decided to run at its own pace. It usually shows around 1200rpm at full throttle. I checked the cable in the back of the cluster and it seems to be OK. You have to replace the whole guage cluster just to fix the tach and that about $700 cdn from the dealer. Does anyone know of a replacement tach that will work, and is there a sending unit in the engine to run a electronic tach? Thanks
richard in nz
04-29-2007 02:45:34
 Re: 5140 tach not working in reply to Colin Kent, 04-28-2007 04:02:18
Engine driven elecric thacometers somtimes take their signal from the alternator, it is usually terminal marked 'W'. Some times a malfunctioning thaco is the first signs of an alternator going down. It may have a crank sensor near the front pulley like on the Claas tractors (Deere engined) which I work on, which can become loose and get ot of adustment, another place to look is the flywheel area for a sensor to check its adjustment.
