is a 2394 a good tractor
georgeguido
04-26-2007 04:11:53
I am looking at a 2394 with 3500 hrs. I'm wondering about the transmision. Also cold weather starting.
Wilson2
04-28-2007 05:19:19
 Re: is a 2394 a good tractor in reply to georgeguido, 04-26-2007 04:11:53
I have owned two 504 powered tractors with the partial PS. Both of them were great tractors. The 504 is a very good engine used on may other models, so parts are available and easy to find.
dboll
04-26-2007 05:16:13
the 504 should start very good if everything is in shape, batteries ect., I am not afraid of any case powershift if operated properly, and the 94 series had the updates. a 2394 is a good workhorse, economical and powerful, it should have around 180 hp as most ran way over factory rating, do remember it only has 1000rpm pto
Jon K MN
04-26-2007 05:09:41
On one farm that I worked on they had a 2390 that I drove for 5 years back in the early 90's .That tractor is still going today.The only trouble we ever had with it was some times if you put the trans. in park with a heavy load on it like the augar wagon or honey wagon full while sitting down hill you could not move the shift leaver out of park unless you pulled from behind with another tractor to release the pressure on the transmision.Sorry it wasn't a 2394.They also had a 3594 but they have since traded that tractor for something much bigger it was a good tractor when I drove it.
