case 731 comfort king wiring diagram
jmw132001
04-25-2007 19:23:14
does anyone have a wiring diagram for a case 731 comfort king farm tractor? it is a 4 cylinder diesel. thanks
GEOM0
04-26-2007 12:16:18
 Re: case 731 comfort king wiring diagram in reply to jmw132001, 04-25-2007 19:23:14
I HAVE A WIRING DIAGRAM FOR 831.
I DO NOT KNOW HOW TO ATTACH.
IT WAS SENT TO ME, MIGHT SEARCH BACK A YEAR OR TWO.
bradley martin
04-26-2007 07:08:08
You shouldn't need a wiring diagram to wire the manifold heater....wire from key to solenoid, heavy wire from starter terminal to solenoid and heavy wire from solenoid to glow plug.
Jim B.
04-25-2007 20:34:13
The operators manual for our 800B (801) has a wiring diagram. Not exactly a schematic, more like a pictorial showing the electrical components and wiring connecting it all together. Could be used to make replacement or repair wiring.
Have you check your manual?
jmw132001
04-26-2007 05:45:19
 Re: case 731 comfort king wiring diagram in reply to Jim B., 04-25-2007 20:34:13
i have checked but did not see anything. i also contacted a few places around my area and they do not have anything at all. what i am needing to do is to wire up the intake heaters so that when it is cold the old diesel will start. And the only other thing i gotta wire up is the lights but i may not need a diagram for those. Thanks
jmw132001
05-10-2007 19:44:37
 Re: case 731 comfort king wiring diagram in reply to jmw132001, 04-26-2007 05:45:19
I finally got it wired up the way it needed to be. Thanks to the person who sent me the wiring diagram. (sorry i don"t know your name). Thanks for the help.
Jim B.
04-26-2007 20:33:38
Consider this statement as just one guys opinion... but I've never been a fan of the diesel manifold heaters. Perhaps it's because our farm is in SE Michigan and the winters have not been that bad lately... you know, global warming and all??
We have 5 Case Diesels on our farm. Smallest is an 800, largest is a 2870. I don't use the manifold heaters and all are functional, although our newer 70 series Cases don't have heaters. Much, much more important is good healthy batteries. The manifold heaters only drain the battery when the starter needs it most. These heaters warm the small amount of air inside the intake manifold. Which is sucked into the combustion chamber and exhausted with only two revolutions of the engine while trying to start. If it doesn't start the incoming air is again cold. My preference, use a gas tractor during winter. If you must start the Diesel, charge the battery for a bit before attempting start and then crank it for about 10-15 seconds, to pump up oil pressure, then spray only 1 sec of starting fluid into the intake stack (not directly into the manifold) and she will start every time. We use our 580CK backhoe/loader to clear snow and have used that starting method for 25+ years.
