430 lck should I
higg
04-25-2007 15:22:01
Im looking at a 430 lck with leaking steering rams .since Im new at this I dont know how hard that is to fix or whether I should shy away from this tractor .any guidance wuold be appreciiated
Thanks Tim
dwell
04-27-2007 16:54:31
 Re: 430 lck should I in reply to higg, 04-25-2007 15:22:01
I just rebuilt one of the steering cylinders on my 530 ck. The kit was only $10 from the case dealer and contained all the needed o rings and seals. Pretty easy to install too.
higg
04-28-2007 09:46:25
 Re: 430 lck should I in reply to dwell, 04-27-2007 16:54:31
thank you for input ill go ahead and buy the tractor Tim
TimBinWV
04-25-2007 17:47:19
Leaking hydraulics aren't usually too difficult to deal with...the most it can set you back is a couple of hundred bucks...depending on what you're giving for the machine,that's not too big of an issue. If you're paying a premium price for the tractor,see if the current owner will split the costs...
higg
04-25-2007 17:57:14
 Re: 430 lck should I in reply to TimBinWV, 04-25-2007 17:47:19
thank you for input it helps alot
