Setting depth on eagle hitch plow
Scott KY
04-25-2007 13:14:16
I have been plowing with a 400 and a BER eagle hitch plow. If I drop the eagle hitch to the float position the plow runs to deep. I have been trying to adjust it by shortening the top link. The turnbuckle on the plow is at 22 1/2 inches. Should I adjust it with the turnbuckle or the top link? My owners manual for the plow says to decrease the depth by lengthening the top link or the turnbuckle. This seems backward to me. Does anyone have any tips on setting the depth on this plow. It is a 3 bottom.
george md
04-25-2007 20:16:14
 Re: Setting depth on eagle hitch plow in reply to Scott KY, 04-25-2007 13:14:16
Scott,
Lengthening the top link will decrease the
depth , but will only work if the furrow wheel is
properly adjusted . By lengthening the top link
you are making the furrow wheel carry the draft
load . I started plowing with one of those plows
in 1954 and I have one around. You do not need a
gauge wheel on those plows. You said you have the
book for it , look on page 29 and it shows the set up for the furrow wheel. Questions , send me an email , I have the manual also.
george
John Saeli
04-25-2007 14:23:08
Many of the plows had an adjustable wheel that ran on the land that was for depth. Your manual is correct though. By lengthening the top link, it picks the front of the plow up thereby shallowing up the depth they go in.
Scott KY
04-25-2007 14:58:05
 Re: Setting depth on eagle hitch plow in reply to John Saeli, 04-25-2007 14:23:08
Thanks, John
I am trying to put a gauge wheel on this plow. I have found some of the parts I need to make it work. I am still lookong for the hub that the wheel mounts to.
