engine oil
Gortex
04-25-2007 11:06:15
Can you run 5w 40 synthetic motor oil
in a older case 800 tractor ?
Thanks
Gortex
Jiles
04-26-2007 09:51:21
 Re: engine oil in reply to Gortex, 04-25-2007 11:06:15
By switching oils, you stand a good chance of developing oil leaks. This is because of different oil seal swell properties of the different oils.
JoeBob/IN
04-25-2007 12:38:15
I can't imagine why not as long as it is rated for compression ignition engines (diesel engines). I have some really good full synthetic 5w40 from Amsoil for my '96 GM diesel. About the only engines that I can think of that require special oil are the 2 stroke Detroits, require a non-detergent oil, I think! Someone will correct me if I am wrong, hopefully anyways.
