how and where do i check the motor oil
sugarfree
04-24-2007 19:37:13
i have a 1939 case wide front end
C. Amick
04-25-2007 09:11:14
 Re: how and where do i check the motor oil in reply to sugarfree, 04-24-2007 19:37:13
Some models have pipe plugs located on the side of the oil pan. The oil level should be at the upper plug. You can replace the plugs with radiator drain cocks to make it easier to check the oil.
Brian in Ohio
04-24-2007 20:41:13
Need to be a little more specific. Which model do you have?
