Case 400 Hydraulic/Tranny Fluid
Taylor Tinsley
04-22-2007 11:41:50
Here's my question: In my Case 400, does it have hydraulic and tranny fluid combined or are they seperate in their own resevoirs?
It looks like I need to bleed all hoses before doing this - not really sure. any info on how to bleed and refill these fluids would be useful. Thanks.
Patrick Tercho
04-22-2007 15:54:44
 Re: Case 400 Hydraulic/Tranny Fluid in reply to Taylor Tinsley, 04-22-2007 11:41:50
If you mean the big 400, the hydraulic and transmission fluids are separate. Hydraulic unit takes ATF type "A", but you can use hy-tran type fluids fine. Tranny uses 80w-90 gear lube. Honestly, I've never loosened the hoses and drained the fluid from the lift cylinder, but would make for a more thorough flush. The hydraulic filter is meant to be cleaned and reused, don't throw it out! Good luck with it!
