case rc rod bearings 0.040 undersized
pete rust
04-22-2007 09:40:11
Hi, I believe I have a 38/39 case rc (no nameplate) it is a tricycle style with adjustable wheels and it has a Waukesha engine MD#FC96/ serial #433107. I found this jewel on the side of the road, got her home, and after some tinkering got her runnin, then I went deeper
and discovered that 1-rod bearing was quite loose, after removing bearing cap I found a cap nut was cracked right up the side.I measured the crank and found that it has been ground down 0.040 (fourty thousands)my books claim original spec is 1.7495 and I've got 1.709 and I'm having no luck finding a set (or complete set) of bearings. Folks I would appreciate any recommendations on the subject including actual year/model/paint/decals/brake bands adjusting bolt and spring/starburst grill/fenders, as I plan on restoring it and look forward to making it original (as possible) THANKS!!!! Pete
C. Amick
04-23-2007 09:32:18
 Re: case rc rod bearings 0.040 undersized in reply to pete rust, 04-22-2007 09:40:11
You might try Otto Gas Engine Works, see link below. If they don't have it, they may be able to direct you to someone who does. Some of the "F" Series Farmalls also used Waukesha engines. I think it was the F-14?
pete rust
04-23-2007 12:34:04
 Re: case rc rod bearings 0.040 undersized in reply to C. Amick, 04-23-2007 09:32:18
Thanks C. Amick, I did call Dave at Otto's approx. 2-weeks ago said he did'nt know for sure the availability and would look into it.
But he seems quite busy as I have called back twice per his request, and I'm going to call again mid week, I was just looking for an option.
Thanks again! pete.
C. Amick
04-23-2007 09:35:39
The other option is to have the crankshaft welded and ground to a bearing size that you can find.
wilson
04-22-2007 12:49:37
Might try getting help on oliver site as oliver used waukashaw engines. There is a place in midwest spelizing in these engines but I dont know where. Are you Machinery Pete?
pete rust
04-23-2007 04:13:29
 Re: case rc rod bearings 0.040 undersized in reply to wilson, 04-22-2007 12:49:37
Thanks Wilson, I'll try that and no I'm not machinery pete, just a tractor fan from massachusetts. pete
