930 Vs 931 Crank Shaft
R. Jones93
04-21-2007 12:48:23
Will the crank shaft and other internal parts of an older 930 6 speed diesel fit into the newer 931 8 speed diesel. Also will the heads fit as well. I believe I read awhile ago that you can't change the rear ends due to differences in the clutches.
bradley martin
04-21-2007 18:21:40
 Re: 930 Vs 931 Crank Shaft in reply to R. Jones93, 04-21-2007 12:48:23
Heads will interchange, 930 6speed had a wet clutch with an oil passage through the rear end of crank to lubricate clutch. I guess if you blocked that passage it would likely work, but someone else on here likely knows for sure. Good luck
