Blow by in a David Brown 1210
JRT
04-20-2007 21:29:58
I have a 1210 with around 5,000 hours that has developed a little blow by smoke from the valve cover tube. It does not seem to use a lot of oil though. I am not that familiar with David Browns but I have worked some old Case tractors hard for years with blow by smoke. Is the David Brown the same way or is it about ready for new rings?
mitch furness
04-22-2007 03:57:34
 Re: Blow by in a David Brown 1210 in reply to JRT, 04-20-2007 21:29:58
JRT I own a 1210 and have found these motors very robust. If it is easy to start and doesnt use too much oil and does not feel under powered I would leave well enough alone. Do you have any photos of the old girl?? You could also try the DB club at www.dbtc.co.uk
Cheers
Mitch
