Case 400
Tom Hanson
04-20-2007 08:33:51
I'm unfamiliar with the Case tractors and have come across a nice little 1959 Case 400. What are your opinions on these tractors? It's got power steering, 540 PTO and a good 3 point. Everything I would need for a chore tractor. Are they a good dependable tractor?
bradley martin
04-21-2007 02:32:38
 Re: Case 400 in reply to Tom Hanson, 04-20-2007 08:33:51
What does the serial # plate say? As "triplerange"stated, if it is a '59 , it is a 400B (which will have a case-0-matic transmission), Your description of the tranny shift sounds more like the 400 built in the mid '50s.They were about 20 hp bigger than the 400b
Tom Hanson
04-20-2007 11:57:08
This has the high/low range stacked manual transmission. If that makes sense? To go from low to high, find center, drop down, now in high. It's also a gas with a wide front.. I'm guessing asking will be around $1k..
triplerange
04-20-2007 09:59:07
If it's a '59 it's a 400b. Nice little tractor about 40 hp. Don't let the case-o-matic (com)scare you. I have a '63 630com with over 7,500 hrs on it. Everything works fine.
triplerange
04-20-2007 09:59:01
bradley martin
04-20-2007 08:58:22
There are 2 400 Case tractors..the big 400 and the 400B which was a completely different machine.Both were fine in their place. If it is a 400B it will have a "Case-o-matic"transmission which can present problems.
