Starting problem with 830
jspencer
04-19-2007 21:32:31
I have a case 830 that I can not get started after replacing the fuel injection Bosch pump. It was rebuilt and installed, the timing was inspected and seems to be correct, after priming and priming, I cann't get the thing to start. Any help would be greatly appreciated. Thanks
R. Jones93
04-20-2007 16:42:08
 Re: Starting problem with 830 in reply to jspencer, 04-19-2007 21:32:31
The slide rail inside the front of the pump may be stuck. On the front of the pump there is a round cap that is fitted to take a 3/4 wrench. Take that cap off and make sure the slide is free. It should be sticking out a little bit. If it is stuck inside the pump it is stuck in the off position.
jspencer
04-21-2007 17:51:34
 Re: Starting problem with 830 in reply to R. Jones93, 04-20-2007 16:42:08
Thanks all, I will try these suggestions this weekend and hopefully she will fire. Thanks
charles hess
04-20-2007 08:03:18
You said it is timed correctly. Did you make sure you had no 1 cyl at correct position(at 31degres tdc on compression stroke)you need to be sure.You might be 360 degrees off an injecting fuel in at start of intake instead of on compression stroke.Other things to look for is if correct timing is done you should see white smoke coming out exhaust as you crank. Assume filters have been bled. Since you just installed pump i would crack a injector line open so pump body can fill up with fuel an as other person said you should see fuel being pumped out.If all of above is correct it may just need a sniff of eather that all of us now we should not use but sometimes it is the answer.
djm75
04-20-2007 04:05:08
have you got fuel at all 4 injectors?
