Pulling LA sleeve
Kim Spencer
04-17-2007 21:22:48
I have 1 bad cylinder in a 49 LA i'm restoring. Made a sleeve puller simular to the one in a LA manual but am unable to get the sleeve loose. Anyone have any suggestions? Also tried filling with ice and heating the block.
Don L.
04-19-2007 05:26:31
 Re: Pulling LA sleeve in reply to Kim Spencer, 04-17-2007 21:22:48
I use the puller disk [ or any heavy metal ]bolted tight to the puller bolt, and hit them out from the bottom with a big mall. My disk has a small lip to fit the bore, and still hits the radius. Works for me everytime. The bolt needs to be big and heavy to "tranfer" the hit of the mall, and your wrists "drive" the hit thru. Too many times I see people use hammers, just to make noise. It is the follow thru with heavy transfer tools the makes the hammer do its job.
lucasd
04-18-2007 15:02:26
If you have access to a welder, and have a replacement sleeve, you might try welding a few beads up the cylinder. Once they cool, it will shrink the sleeve and it should come out easier. If you weld enough beads and it gets hot enough, it should work.
