LA Head Numbers
Steve Wiiest
04-17-2007 19:13:12
Was wondering where I could find out what kind of different head options there where fro the LA and how to tell by what the casting number is. My number is 5844A. Is this a standard head.
Walt Davies
04-18-2007 14:29:16
 Re: LA Head Numbers in reply to Steve Wiiest, 04-17-2007 19:13:12
My48 parts book has this 1. 4447A HEAD (USE 51AA)
2. 5844A HEAD (USE 3943AA)
3. 5845A HEAD (USE 3947AA)
4. 6386A HEAD (USE 4767AA)
IT ALSO SHOWS 2 DIFFERENT PISTONS AND 3 DIFFERENT RODS. THEY MUST BE ALL MATCHED UP TO WORK CORRECTLY.
Walt
Walt Davies
04-18-2007 14:11:57
My tractor has the 5845A head its from an LP engine and has the pistons that are cut to go up inside the oval shaped head. Not sure what the compression is but its not easy to hand crank. Walt
LA puller
04-18-2007 18:00:48
 Re: LA Head Numbers in reply to Walt Davies, 04-18-2007 14:11:57
You have a aftermarket overbore set. They make great power with that cylinder head and realy pull well.
Walt Davies
04-18-2007 20:25:56
 Re: LA Head Numbers in reply to LA puller, 04-18-2007 18:00:48
Not yet i would also like to put in a stroker kit some where up around 750 to 850 CID would be great.
I'm thinking of adding dual carbs this summer.
Walt
Steve Wiiest
04-18-2007 11:08:35
So the LP LA used a diffrent set of pistons then what the gas burners did?? Are those three heads the only options or were there more made??
Thad
04-18-2007 12:07:13
 Re: LA Head Numbers in reply to Steve Wiiest, 04-18-2007 11:08:35
The only other head used on the LAs was 4447A and it was the lowest compression one. As far as i know Case only made two piston types for that motor. One was the high compression piston that was used with the 4447A and the 5844A heads. This piston actually sticks out the top of the block a 1/8 inch or more. It actualy fits up inside the cylinder head. The other piston is a little less than a 1/4 inch down in the bore when all the way up. The 5845 and 6386 wont allow for the popout piston to fit in because of the smaller combustion chamber of these heads. Most after market overhaul kits had flush pistons which will work with any head #. Now Case may have made flush pistons but im not sure. Thad
Thad
04-18-2007 09:05:38
The head you have is one of the lowest on compression. Its combustion chamber is 370cc or so i cant remember exactly on it. The 5845 is 260cc and the 6386 is 140cc making it the highest on compression. The 5845 and 6386 have to be used with pistons that are flush with top of the block or lower. The pistons that stick out above the deck will not work unless milled down. Hope this helps Thad
Engineer20
04-18-2007 07:31:48
My parts book shows the following head numbers:
5844A- standard
5845A- this is what my factory propane number is
6386A- this is also a propane head
Im not sure what the difference is between the second two numbers are.
