Torque Tube
Jon
12-17-1999 04:46:50
Even though my VAC didn't have a hydralic pump on it would there still be fluid in the torque tube for another reason
The only spot that I could figure was the torque tube is right where your feet sit
Larry
12-17-1999 07:23:36
 Re: Torque Tube in reply to Jon, 12-17-1999 04:46:50
You still should keep oil in the torque tube for the few bearings that are in there.
Mike from Canada
12-26-1999 16:53:40
 Re: Re: Torque Tube in reply to Larry, 12-17-1999 07:23:36
I agree. If your tractor has no hydraulics, a 20W oil is adequite for lubrication of input shaft bearings. If the tractor IS equiped with hydraulics then you should consider Case Hy-Tran instead.
