VAC throughout bearing
Tom/Idaho
04-17-2007 12:32:29
Is there a secret way to get the bearing off the clutch arm? I have the tractor split and am replacing the clutch plate/pressure plate but can't figgure out how to remove the bearing.
Any advice will be appreciated. I must be overlooking something. Thanks, Tom/Idaho
scott6143
04-17-2007 19:27:51
 Re: VAC throughout bearing in reply to Tom/Idaho, 04-17-2007 12:32:29
there is a spot on the pivot shart of the release fork that you can get a wrench on, the clutch rod will have to be removed. if you can't get a wrench on the rod you will have to remove the three bolts on the hub the fork is on, I had to. If you remove the hub, you may have to use less shims to tighten up the bearings when you put ti back together.
